Liked 3 Times in 1 Post
2006 Dan Page Swing Arm Dragster
250" Wheelbase - 21" Cage Updated Winter 2011/2012 Current NHRA 2.5B/6.00 Certification Less Engine/Transmission $15,500 Includes: Mark Williams Econo Rear End Housing and axles Bolt-through MW Aluminum 3rd Member 35 Spline Aluminum Spool w/large pinion 4.30:1 Gear Mark Williams Brakes Mark Williams 3.5" Dia Aluminum Driveshaft Ceramic Axle Bearings Weld 16"x16" Alumastar Wheels w/ no screw holes Good Year 33.5X17-16 Weld Alumastar Fronts w/sealed roller-type bearings Good Year Front Runners AFCO Double Adjustable Shock w/Remote Canister Chrome Mono Wing Stand (wing NOT included) Carbon Fiber Suspension Cover Transmission Limiters Aluminum Front and Rear BBC Engine Plates Ron Davis Radiator w/ Fan & Mount Chrome Aluminum Deflector Plate Carbon Fiber Interior & Seat Carbon Fiber Dash for Racepak UDX or IQ3 Display (Display NOT Included) Carbon Fiber Dash Cover Stroud 5 Point Harness Racepak V300SD Mount (Racepak NOT Included) Carbon Fiber Wiring & Accessory Tray MSD 7530T Ignition Dedenbear CC-1 Painless Switches B&M Pro Bandit Shifter - Air Operated Weldon 2025 Fuel Pump Kinsler Fuel Filter @ Pump 3+ Gal Front Mount Aluminum Fuel Tank Master Disconnect w/ Rear & Drivers Cockpit Push/Pull Handles Chrome Dewzen Dial In Board Mount Chrome A Arms & Steering Arms Contact info: 617-771-9725 nealjp@comcast.net pneal_sc119e@yahoo.com
Paul Neal 119E TD/SC Dan Page 265" w/ Martin 632 6.490 @ 205.76 ...all motor! Last edited by Paul Neal; 08-31-2014 at 05:48 PM. |
