Old 10-23-2013, 04:00 PM   #1
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Aftermarket Cast Iron SBC Cylinder Blocks
Is anyone aware of an available aftermarket/performance cast iron cylinder block that is machined for a small-journal crankshaft? I'm looking for options for next year.
Thanks!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 10-23-2013, 05:57 PM   #2
Default Re: Aftermarket Cast Iron SBC Cylinder Blocks
Not that I am aware of. Dart might be interested in making a run of them, but I wouldn't hold my breath.
I'd say your only hope is to go on a quest for a small journal Bow-Tie block, good luck with that. Have not seen one in a long time.
Old 10-23-2013, 06:36 PM   #3
CFMCNC
Clevite has spacer bearings to go from 350 main block to 327-2.300dia main crank.Part number MS1110-H.Available in std.-.001 .001X and -.010.Bill C.
CFMCNC is offline   Reply With Quote
Old 10-23-2013, 07:22 PM   #4
Ed Wright
Ed Wright's Avatar
That's what I use.
Ed Wright 4156 SS/JA
Old 10-23-2013, 09:51 PM   #5
carl hinkson
Liked 18 Times in 10 Posts
Originally Posted by cfmcnc View Post
clevite has spacer bearings to go from 350 main block to 327-2.300dia main crank.part number ms1110-h.available in std.-.001 .001x and -.010.bill c.
x2
carl hinkson is offline   Reply With Quote
Old 10-24-2013, 12:18 AM   #6
Lew Silverman
Thank you all for sharing your knowledge. I myself had never seen one, but I've been told to "never say never"! I was just hoping that I wouldn't have to repeat my "buy three and get two boat anchor's" fiasco of two years ago.
Now I have some shopping to do!
Lew Silverman #2070
Old 10-24-2013, 08:55 AM   #7
gbur
May have a 327 block in the garage Yep ,have one casting # 3903352
gbur is offline   Reply With Quote
Old 10-25-2013, 08:03 PM   #8
Bowtieguy1967
Race Engineering offers main bearing spacers that allow the use of conventional small journal bearings in a medium journal block.
http://www.raceeng.com/p-7689-bearin...27-to-350.aspx
I used a set of these in a 350 block with a 283 crank and they worked fine. Be sure to check the tang notches though, the one for the rear main was slightly off location on my set which required a little hand-fitting to avoid binding the bearing, no big deal but it does need to be checked.
Bowtieguy1967 is offline   Reply With Quote
Old 01-07-2014, 11:20 AM   #9
gbur
Any takers
Old 01-07-2014, 07:27 PM   #10
randy wilson
Liked 22 Times in 22 Posts
Dart will cast you anything you want in a block within reason. ANYTHING! But, be prepared to spend some $'s.
don,t have one
