Old 10-22-2013, 02:08 PM   #1
Michael Compton
Liked 59 Times in 13 Posts
Default 1992 Camaro Super Stock & Modified
1992 Chevrolet Camaro
Currently setup for SS/BS
Previously ran GT/DA & EA
Ran best of 9.00 @ 148 in Noble 2013
Comes with 2 hoods (modified and flat hood for SS)
Mark WIlliams brakes installed in 2012
Mark Williams axles
Indy Gear MW 6.20 center section with Lamb pinion support (less than 50 runs)
Turbo Start Battery
Inland Empire aluminum driveshaft
Racepak V300SD with water temp, oil press, fuel pump press, carb press, vac press, trans press, 2 AFR sensors, driveshaft sensor
Racepak IQ3 digital dash
Larry Larson stainless steel headers with Performance Welding collectors
Lamb/Koni front and rear shocks
Santhuff front springs
2 sets Weld wheels with Goodyear radials
I am sure there is more that I am missing. Car will be sold without motor, trans and shifter. Car has less than 150 runs since first run down the track in 2006. Very well taken care of and maintained.
$30,000 firm
Call Michael at 417-437-1669 or email mcompton@kandccpas.com for questions or pictures.
Michael Compton is offline   Reply With Quote
