Old 10-05-2013, 05:50 PM   #1
ss wannabee
Liked 7 Times in 7 Posts
Default 12-bolt axle selection?
Best way to combine lightness...with dependibility..on a 3500-lb car...283 and PG...
small tire too...might be foot-braked also...
1. 35-spline....gundrilled and lightened flanges....
2. 33-spline....with lightened flanges....
3. 33-spline...with no lightening...
Realize one or two companies will gundrill the 33 spline...but being a heavier car...
might not be the ticket? Figuring on an axle length of about 27/28 inches....(still
measuring tire and rim combos...and not set on final housing dimension yet.)
Thinking of finishing...with a lightweight steel spool...and housing ends...any favorites
on these? Ring gears have been lightened....
Wondering if the fact that the "hit" is less...(footbraking)...that I might be able to get
by with "less" axle...the 33?
Your input is appreciated!
ss wannabee is offline   Reply With Quote
Old 10-05-2013, 07:18 PM   #2
ss wannabee
Default Re: 12-bolt axle selection?
One thing I might add...and this is my opinion...the difference in weight between the
33 and 35 is probably not too much....and by the time you "work" the 35...you're
near (or at) the 33 ????
There is the strength factor...by having the larger diameter...and 2 extra splines...
but I don't think it's that much more than the smaller shaft....
Do I sense that a lot of racers are using the "street/strip"...or "hy-torque" material
axles...instead of the "race" type....especially in lower hp or stock classes?
Certainly less expensive...wonder if they'd be ok here?
Old 10-06-2013, 12:28 AM   #3
randy wilson
Liked 22 Times in 22 Posts
Any of those will work. Have used 33 spline in a 92 camaro, 3,000 lbs. clutch leaving at 9,800, never broke a thing. Put 33 spline, rifle drilled, in a 67 nova SS\EM if I ever get to race it.
don,t have one
Old 10-06-2013, 05:34 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Ran non lightened Moser 33 spline axles with their spool for many years without issue in my nearly 3880 lb., small tire, footbrake launched Chevelle whose best 60 foot was 1.28.
