Old 09-26-2013, 09:36 AM   #1
BOB A
Default 1995 ZR-1 Corvette Prepaired by John Lingenfelder
1995 Lingenfelter Prepared Chevrolet ZR-1 Corvette Coupe-
This 1 Owner Corvette with 27,186 mile's was equipped from the factory with the ZR-1 package and 6 speed manual transmission - Roof Package and Bronze Removable Roof Panel - With an MSRP from Chevrolet of $69,653 - Then sent to John Lingenfelter ($30,400) in February of 1996 the 5.7 Chevrolet Motor was taken to 385 C.I. the Cylinder head's were Ported and given a 3 angle valve job and re-surfaced before being installed - the entire rotating assembly was blueprinted and balanced along with the camshaft being degreed - the crankshaft was a custom stroker unit along with the forged aluminum piston's - included are the plasma moly file fit piston ring's - the connecting rod's were provided by Oliver and are billet steel - the Injection manifold was fully ported along with the Plenum and Injector housing - a set of Callaway Header's were installed ($2200) - Borla Exhaust was installed - the rear differential gear set was changed to a 4:09 ratio along with a LPE speedo recalibration for the new gear set - Ron Davis provided a new all Aluminum Radiator - K&N Cold Air filter - the end result is a pump gas street ride with 575 HP (LINGENFELDER DYNO WITH SHEET'S) - Feel free to call 508-two six nine-9611 or e-mail ba1927@aol.com with any question's - All Original Factory Documentation along with the Lingenfelter Performance Engineering Dyno Sheet's and Invoice for there work completed $39,995
BOB A is offline   Reply With Quote
