Old 09-23-2013, 11:03 PM   #1
nwebber
Liked 39 Times in 5 Posts
Default 83 malibu wagon klm/a
Car is very consistent and only needs a good driver to win rounds. Just won the Sunday Walla Walla National Open on 9/22/13.
305 flat top combo rated at 248hp (Camaro with the engine is rated at 263)
CP pistons
Greg Luneack Rings and crank
Manley rods
Bullet Cam
Smith lifters
Heads are from Heads Up but outdated, freshened by Terry Malm
PAC beehive springs
ATI converter
Coan XLT 350 trans 2.70 low gear
Moser lightweight spool and axles
Spares include fresh short block (tenth and half slower than current short block), two intakes (aluminum and cast iron)
Universal case T350 with 2.75 low gear (need freshened)
Will run .55-65 under in bracket mode and heavy
Hooks every time, you can run up to 38lbs in radials without fear of spinning the tires in a heads up round
pictures under norm webber on autoimagery.com
$13,500
Norm Webber 503-572-2799
Norm Webber
nwebber is offline   Reply With Quote
