Old 09-19-2013, 09:50 AM   #1
strange1
strange1's Avatar
Default Collecter Tethers?
The headers on my stock eliminator car are one piece. However, I use an extension/reducer that bolts to the flange. Am I required to install a tether?
Any information/insight is appreciated,
Robert Strane
Stk 2061
strange1 is offline   Reply With Quote
Old 09-19-2013, 10:08 AM   #2
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: Collecter Tethers?
Good question, I would say yes, seeing you can't have the collector bolted to the pri. pipes with tabs, they have to be stitch welded.You might have to weld the 2 flanges together,making it 1 piece.Give the tech dept. a call.
Old 09-19-2013, 11:57 AM   #3
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Now things are getting carried away,
I read that as he has a collector extension bolted to the flange, not the primary tube tabs.
Is this the typical street style 3 bolt flange at the end of a collector?
Old 09-19-2013, 12:13 PM   #4
drgrcr1156
Liked 2 Times in 1 Post
Can't the bolts on his extensions loosen and fall off like on the primary
tube tabs?
drgrcr1156 is offline   Reply With Quote
Old 09-19-2013, 12:23 PM   #5
gsa612
gsa612's Avatar
That's the way I read it.
Old 09-19-2013, 12:26 PM   #6
gsa612
gsa612's Avatar
tube tabs?
Your chances are better to win the Powerball, than that happening. lol..
Old 09-19-2013, 05:11 PM   #7
Mike Gray
Mike Gray's Avatar
Hope you don't need the 36" tethers instead of the 10", 15" or 20" ones.
They are $50.00 more for an extra 32" of stainless 1/8" cable that sells in bulk for less than .50 cents a foot.
surprisingly the 10", 15" and 20" all cost the same
Old 09-20-2013, 08:32 PM   #8
strange1
strange1's Avatar
tube tabs?
Yes they can, however, per NHRA we have them jam nutted so that happening is not probable. They are bolted to a street style three bolt flange. My concern is finding a company that makes the rings in which the tethers attach too in a large enough diameter to go around the three inch header and extension. I could make something work, but NHRA is mandating the use of a particular brand that they have approved, thus, making this more problematic.
Robert Strane
Stk 2061
Old 09-20-2013, 08:35 PM   #9
strange1
strange1's Avatar
Welding the two flanges would be the easiest way, but it would make it difficult to remove the headers. It may even make them impossible to remove as I have not tried to remove them with the extensions on.
Robert Strane
Stk 2061
Old 09-23-2013, 08:42 AM   #10
T Ketels
I wonder if it would be legal to use v-band type flanges and clamps at each junction much like boosted cars run on the hot and cold side of their induction/exhaust systems. Surely with a welded v-band flange and clamp on the end of my collector where it goes into the extension, this would not require a tether - or would it?
Tim
SS/MA
5017
T Ketels is offline   Reply With Quote
