Old 09-09-2013, 06:38 PM   #1
Wisman Racing
Wisman Racing's Avatar
Liked 4 Times in 2 Posts
Default Msd 7al 3
Hey guys, I'm running out of ideas. The retard timing terminals on my box are getting energized as soon as I turn the Ignition on. The terminals are reading 8 volts to ground as soon as I put 12 Volts to IGN. I put a friends box in and it does the same thing. \
If I bench test it. I read 381K Ohms between Ign and all the retard terminals with no wires connected. The 8 Volts is enough to activate the timing if I put a pill in. I have checked grounds and wiring.
Any Input is appreciated. Thanks.
Wisman Racing is offline   Reply With Quote
Old 09-09-2013, 07:01 PM   #2
SPS
Liked 3 Times in 2 Posts
Default Re: Msd 7al 3
John:
Call me.
The AL3 is different than the others and requires the chips be in all the holes.
FJ
SPS is offline   Reply With Quote
Old 09-09-2013, 11:08 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
FJ is correct. ..If you don't use the retard feature ,you must put zero pills in all the sockets.
I also have the terminals grounded , ....MSD recommends this if there are no pills installed, but I do both in case a pill falls out.
Old 09-10-2013, 12:32 AM   #4
Liked 1,829 Times in 414 Posts
These guys are correct, the 7AL-3 requires zero chips where no function is desired.
