Old 09-01-2013, 04:58 PM   #1
Joe DeMarzo
Liked 113 Times in 9 Posts
Default Piston perfromance
Ok, so I am home and not at Indy racing so my mind starts thinking.....
How much performance difference is there between "flat with notches pistons VS a dish piston"? All other things being equal, valve, cam, same carb etc...
Doubt anyone has back to back this but someone has to be smart enough to figure this out.
P.S. the last thread on FI vs CARB was great.
Joe DeMarzo 1317 STK
Old 09-01-2013, 07:07 PM   #2
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Re: Piston perfromance
Flat pistons should give a better quench and more efficient burn. There is a trend toward d-shaped dishes for big inch pump gas engines, to keep a good quench and still lower compression.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 09-01-2013, 11:10 PM   #3
Chris Hill
Liked 244 Times in 26 Posts
I don't think you can look at an A to B comparison for piston top for performance.
If you ask,"What effect does combustion chamber shape (head and top of piston) have on engine performance with everything else the same?" I think that is what you mean.
Chris Hill
Old 09-02-2013, 08:43 AM   #4
Joe DeMarzo
Chris, Chipper or anyone else: would a flat piston with notches be faster than a dish piston (everything else is equal)?
I thought the dish allows for a better burn rate but losing out on compression. Would you advise some one to build a dish if it was rated 20HP less than a flat with notches?
Would the combustion chamber in one be that much better than the other?
Old 09-02-2013, 09:17 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Joe,
Assuming comparable compression ratio, there are instances in SBC Super Stock combinations where a properly shaped dish has a alight advantage over a similar combination with a flat top piston with valve reliefs. There are lots of other factors in that equation though, not just the dish vs. flat top comparison. That being said, the shape of the dish is critical for the advantage. For Stock combinations, the factory dish shape is a disadvantage in every situation I have seen.
Old 09-02-2013, 10:52 AM   #6
carl hinkson
Liked 18 Times in 10 Posts
Same compression and reverse dome VS flat top the reverse dome whens every time.
carl hinkson is offline   Reply With Quote
Old 09-02-2013, 01:29 PM   #7
Joe DeMarzo
Dwight, thank you for the insights on the factory stock dish shape ... there are some 305 combo's that are identical except the piston. The flat top is rated 20 HP more, and killer fast. Was thinking why not run the dish piston -260lbs.
Old 09-02-2013, 01:41 PM   #8
Lee Valentine
Liked 319 Times in 68 Posts
Joe ,I believe there are other differences I think in cameros flat top engines are big cam dish are small cam.
Lee Valentine 1661 STK
Old 09-02-2013, 01:45 PM   #9
Joe DeMarzo
Lee, they are not both Camaro's, one is a Camaro and the other is a different body style.
Old 09-02-2013, 04:06 PM   #10
Dwight Southerland
Joe -
Are you talking Stock or SS? In either case, the flat top engine and the later shallow dish piston engines are at least a point more compression than the early dished piston engines, so its not apples to apples.
