Old 08-12-2013, 01:21 PM   #1
94 S/ST CHAMP
Default Trailerworld 21ft aluminum racecar trailer
Can deliver to the us nationals in indy!!!-trailer world inc. 20ft all aluminum tandem axle racecar/showcar trailer with heavy duty winch plus other extras, less than 500 miles, used less than 10 times to transport a corvette road race car to our local track, this trailer has some trick add-on's to benefit a low sitting racecar such as ramp extensions and "risers" mounted on the deck to raise your car up which makes it much easier to tiedown and secure your car, the aluminum tire rack is bolted on and can be removed if needed, (you can also easily modify and enclose the tire rack and turn it into a nice toolbox??), removable fenders on both sides, heavy-duty winch and battery mounted inside an all aluminum box, this trailer has brakes on both axles, led lights, 4 brandnew trailer tires, 2 5/16 heavy duty coupler, safety chains, bulldog jack, super lightweight, easy to load, and ready to use today!! Pulls like a cadillac!! Only $5300.00, 901-219-956nine
94 S/ST CHAMP is offline   Reply With Quote
