07-29-2013, 08:36 AM | #1 |
Liked 220 Times in 95 Posts
Trailer tire failure
All you guys out there pull trailers with your race car on them, right? How do you know when you have a flat? I've had 3 and I only knew about one cause I heard it blow. The other 2 I was told by a passing motorist. My boy found this neat little gadget called a TPMS, tire pressure monitering system. The valve stem caps have little transmitters in them that send the tire pressure and temperature to a receiver that you have in the cab. It sends an alarm when tire pressure drops 3 pds and it tells you which tire. It won't save me from having a flat but it will save me from tearing up a fender when the tire shreds.
Floyd Staggs 787 SST |
07-29-2013, 08:43 AM | #2 |
Liked 1,739 Times in 551 Posts
Re: Trailer tire failure
same here, usually a very loud bang! do you have a link to this monitor system? or an idea of price? may be something to look into.
KEITH MAYERS 2 X somebody many X nobody |
07-29-2013, 08:48 AM | #3 |
Hey Keith,
They are just now being brought into the states. They have a list of $345.00. Davies Craig Tyreguard 400. I got the first one. USA Warehouse 3P Connect USA 9469 Richmond Place Rancho Cucamonga CA, 91730 Tel: (909) 476-6068 Fax: (909) 476-2594 E-Mail: sales@3pconnect.com Web: www.3pconnect.com
Floyd Staggs 787 SST Last edited by Floyd Staggs; 07-29-2013 at 08:55 AM. |
07-29-2013, 09:30 AM | #4 |
Liked 2,934 Times in 901 Posts
These are popular with the RV crowd...the folks at Techno RV are real pros
http://www.technorv.com/TireTraker_T...p/tt400c-4.htm#
07-29-2013, 09:37 AM | #5 |
That's looks like the same one private labeled.
07-30-2013, 12:01 PM | #6 |
Liked 220 Times in 79 Posts
Camping world sells a couple of different models of them. Have not tried one myself but it does seem like a good idea. Especially if it will report temp as well. I just took a look over there after I saw this. All the ones they sell are discounted right now some as much as 90 dollars discounted.
07-31-2013, 08:14 AM | #7 |
I had two on my 48'. One was coming apart sitting in the storage lot, the other was running down the freeway at 65. It let me know it was flat. I couldn't believe how much it shook the truck.
Next time wave all of your fingers at me. |
