76 camaro I/SA 350 40 over, cp pistons, Bullet cam, any idea what cranking compression we should have. Just would like to know.cam is in at 98
Thank You |
Liked 2,486 Times in 697 Posts
MY 9.5 to one Mopar Small Blocks run approximately 160 lbs.
Liked 129 Times in 59 Posts
Lonnie,
The numbers may not tell you very much when you are looking for a "high" value. The compression test is a good way to tell if any one (or a number of) cylinders is having a mechanical problem. What you look for is a pattern where each of the cylinders is within 5 to 10 psi of the others. It has been my experience that a "leak-down test" is a much better gauge of engine health and efficiency when done properly. The kit is not that expensive and only requires an air-compressor capable of 100 psi of pressure. Done on a regular basis, it is a much more accurate diagnostic tool. Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
