Old 06-17-2013, 11:24 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Question Maximum rear wheel spacer vs. safety issues
Using aftermarket 5/8 rear wheel studs, would 1" thickness wheel spacers be too much for safety on a stocker ??? What would be the maximum ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 06-23-2013, 05:43 PM   #2
GTX JOHN
Liked 2,486 Times in 697 Posts
Default Re: Maximum rear wheel spacer vs. safety issues
Yes!!! I broke a bunch of ribs and knocked down the tree and destroyed
a car at the Winters' with 1/2" billet spacers.......Just my opinion.
Old 06-23-2013, 06:05 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Rusty, there are always "conditions/exceptions"
From personal experience S & W will build water jet cut aluminum spacers at least 1" thick. I have a 1" set on a dragster that runs 4.80's and a 3/4" set on a door car that runs 6.10's
I know others who also run thick spacers. I think the key is a spacer that fits the studs exactly/snugly and checking wheel nut torques OFTEN! I think it is possible that some lug stud failures happen because the tightening torque is not checked and the fastener per-load becomes insufficient.
Larry Woodfin 471W
Old 06-23-2013, 08:44 PM   #4
Run to Rund
Liked 54 Times in 27 Posts
Please get the correct offset wheel instead. Even if bodywork doesn't bother you, the guy next to you will be grateful.
Old 06-23-2013, 11:30 PM   #5
Bob
From the rule book:
The thread engagement on all wheel studs to the lug nut, or lug bolts to
wheel hubs, must be equivalent to or greater than the diameter of
the stud/bolt. Length of the stud/bolt does not determine
permissibility. (Example: A 7/16-inch stud must be thoroughly
engaged through the threads in the hex portion of the lug a
minimum of 7/16-inch.)
Wheel spacer permitted. Spacer to be either hub-centric or lug-centric
and must fit with minimal clearance to retain concentricity. The wheel
spacer must not reduce the minimum permitted thread engagement
below the limits established by fastener diameter.
Although it's legal, as others pointed out, it may not be safe. The correct offset weels would be better.
Bob is offline   Reply With Quote
Old 06-24-2013, 10:21 AM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
The key to running spacers is what Larry pointed out. They need to fit snug on the wheel stud, and have adequate torque applied. The 5/8" studs do not allow for a shoulder style lug nut. The problem with running spacers with 1/2" studs, is the engagement of the lug nut shoulder allowing flex in the stud. If the stud is allowed to flex, you will have bad things happen. After having 4 out of 5 wheel studs break when I first got my car back together several years ago, I was running 1/2" studs with spacers. The stud was flexing at the brake rotor hat, as the lug nut shoulder did not engage in the full depth of the spacer. Since switching to 5/8" studs and billet spacers, I have never had an issue. When servicing the brakes, I have to work the spacer off the studs to remove them.
Get the tire and wheel to fit the car with spacers, then if you choose to buy a custom offset wheel you know exactly what you need.
Sean
Sean Marconette
84 Mustang
5060 SS/N
