Old 06-14-2013, 05:32 PM   #1
vetteboy
Liked 2 Times in 2 Posts
Default Front end alignment 67 vette
I almost have the car ready for its first test run. I need to have the front end aligned and look for alignment specs 67 vette. Thanks Brett
vetteboy is offline   Reply With Quote
Old 06-15-2013, 09:28 AM   #2
jims5600
Liked 21 Times in 9 Posts
Default Re: Front end alignment 67 vette
vetteboy do you need street specs or race alignment specs?
I put a post up on one of the Vette forums Iam on and Iam sure
someone there will have some insight.
Jimmy
jims5600 is offline   Reply With Quote
Old 06-15-2013, 09:44 AM   #3
Liked 1,831 Times in 415 Posts
If this is a class race car with OE style suspension, for drag racing only, then, with the front end raised about 1-1/2" from static ride height, you need 1/16" to 1/8" toe in, 0 degrees camber, and as much positive caster as you can get.
Old 06-15-2013, 11:52 AM   #4
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
I would contact Billy Nees. He did a great job on all our Corvettes.
Jeff Jewell
Old 06-15-2013, 12:05 PM   #5
vetteboy
It has OE suspension and will be a drag car only. Thanks for the information. Brett
Old 06-15-2013, 05:55 PM   #6
jims5600
vetteboy, check this web site,
www.guldstrand.com/alignment.asp
Old 06-15-2013, 08:33 PM   #7
Ed Wright
Ed Wright's Avatar
There ya go ^^^!
Ed Wright 4156 SS/JA
Old 06-15-2013, 10:38 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
If you are using OEM type bushings, the settings will not stay put. Also, without some serious work, you will need to limit the front suspension travel to keep the toe and camber within reason.
Old 06-21-2013, 08:00 AM   #9
L79racer
L79racer's Avatar
I would love to see some pictures of your 67. Could you post some or email some to L79racer@aol.com. Some specs would be nice also. Thanks,
Vinny
L79racer is offline   Reply With Quote
Old 06-21-2013, 08:07 AM   #10
Greg Hill
Liked 279 Times in 68 Posts
If you want it done right contact Richard Doane in Dayton. Shop number is 937-279-1187.
Greg Hill 4171 STK
