Old 06-14-2013, 01:04 AM   #1
stang321
stang321's Avatar
Default Drag radial
Simple question to anyone that may know the answer. Are drag radials legal in stock eliminator and if so are there size requirements. Are you limited to a 235 or 255 or 275 etc. any input would be greatly appreciated.
Mike Fowkes
stang321 is offline   Reply With Quote
Old 06-14-2013, 02:35 AM   #2
Michael Colaluca
Default Re: Drag radial
Yes they are. We have to use a 9in slick. So whatever you measure across on your drag radial, make sure it doesn't go past that.
I forget the exact measurement that NHRA placed in their rule book. I think it was 9.5 across max including wear?
Michael Colaluca is offline   Reply With Quote
Old 06-14-2013, 06:30 AM   #3
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
There are a few running the 275 street radial.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 06-14-2013, 09:39 AM   #4
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
I asked about this for a whole year and no one had a clear answer. They will get the tape measure out for the 235/255/275 but not for anything that says 9" on the side, where you can clearly see stocker tires being stretched to 10+ inches. Run at your own risk. I had to settle on a bias play 28x9 for my stocker because I couldn't fit the traditional 30x9 radial under it.
'65 Mustang SS/L & L/SA
Old 06-14-2013, 05:46 PM   #5
stang321
stang321's Avatar
Thank you for responding. I figured it was a gray area as with most of stock
