Old 06-12-2013, 11:04 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Playback tach ??
Any ideas on what may be happing?
I don't have a race pack.
On the Playback tach
1st gear is real smooth to 6000
2nd gear it falls back an sits for a bout 1 second (in slow play back mode)
then climbs slowly and "hops" a bit. to 6000
3rd it falls back to the same spot climbs slowly
from 6300 on it starts" jumping & hopping" real bad.
I don't know what this is the tach looks smooth when making the run
the car doesn't miss or pop and runs a decent MPH 122 IN D/SA
Any help or ideas on what is causing this would help, thanks.
MEXJOE is offline   Reply With Quote
Old 06-13-2013, 04:09 AM   #2
GTX JOHN
Default Re: Playback tach ??
All our playback tachs are jerky when played back
in slow motion ...particularly in high gear as they are
moving up more slowly.
On the shifts they drop back momentarily to the converter
stall speed as well have large ratio changes in our transmissions.
Despite this they provide a lot of information to us.
Old 06-13-2013, 08:01 AM   #3
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
x2
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 06-13-2013, 06:53 PM   #4
G Anderson
Liked 4 Times in 3 Posts
Glen:Mines an older Autometer I bought used but it has always worked real well ! I would say check your ground---
G Anderson is offline   Reply With Quote
Old 06-13-2013, 08:11 PM   #5
novassdude
Liked 136 Times in 49 Posts
You may want to look at getting a noise filter to cleanup the power and ground.
That and check the grounds. The majority of issues we find at work are ground related.
novassdude is offline   Reply With Quote
