Old 06-12-2013, 02:13 PM   #1
Paul Ceasrine
Liked 10 Times in 10 Posts
Default 1968 'Plymouth Road Runner vs. Pontiac GTO'
The '1968' Battle of the mid-sized body Dealership Musclecars.
Plymouth 383 Road Runner
* Engine............383/335 HP
* Car Weight....#3424 lbs.
* Wt/Hp.............10.22
Released on September 12, 1967
A 'bare-bones' Belvedere, with a some 'novelty emblems' and a Power-Bulge Hood with 'non-functional' air-induction vents.
An improved 'steady-and-durable' 383 now rated at 335 HP, thanks to the addition of the Camshaft and Valve Springs
from the 440 Super Commando, as well as an Oil-Pan Windage Tray.
For good measure, the 'wind-swept design' Exhaust Maniolds from the 440 Super Commando (with 2 1/2" Header-Outlets}
were added, to improve exhaust flow.
Not necessarily designed for the Drag Strip { NHRA E/S or E/SA Class }, but more for the young Street-Racer
ie; ''Budget-Minded Econo-Racer" who could only afford $3000 for a performance car.
Old 06-14-2013, 08:37 AM   #2
Paul Ceasrine
Default Re: 1968 'Plymouth Road Runner vs. Pontiac GTO'
1968 Pontiac GTO
Engine...............400/350 HP {Standard}
Car Weight.......#3504 lbs.
Wt/Hp................10.01
Released in September 1967
A 'dressed' up version of the 'Original Musclecar', with a few more bells and whistles, as well as a new design.
Available with the 'Standard' 400/350 HP, generally a good street performer.
Also to be classed in NHRA E/S or E/SA, but this version was more of a 'Gentleman's Musclecar'.
Old 06-15-2013, 08:41 AM   #3
Paul Ceasrine
Jack,
When they both were introduced in the early Fall of 1967,
The Road Runner was only available as a 'Pillared-Coupe'.
The GTO was available in both the 'Hardtop' or 'Convertible'.
After January 1968 (mid-year addition) the Road Runner was available
in the Hardtop Model as well.
Old 06-17-2013, 07:16 AM   #4
Paul Ceasrine
1968 Plymouth Road Runner
Pillared Coupe with the 383/335 HP 'H-Code'
Base Cost {October 1967}...........$2896
Included;
* 4-Speed Manual
* 8 3/4" Rear-End, with 3.23 Gears {Open Rear}
Options
* Sure-Grip.............................................. .......$39
* Torque-Flite Automatic Transmission.....$196
The 'first' Road Runner 'Print Ad' {September 1967 - Hot Rod Magazine}
1968 Pontiac GTO
Hardtop with the 400/350 HP
Base Cost..........$3101
Included;
* 4-Speed Manual {Wide-Ratio}
* 3.23 Gears {Open-Rear}
Options
* Safe-T-Track Differential.................$42
* Turbo-Hydramatic Automatic.......$236
Old 06-17-2013, 08:32 AM   #5
Old 06-17-2013, 09:11 AM   #6
Paul Ceasrine
Standard Equipment Included;
* 4-Speed Manual
Options
* Sure-Grip Differential..................................$39
1968 Pontiac GTO
Hardtop with the 'standard' 400/350 HP
* 4-Speed Manual Muncie M-21 {Wide-Ratio}
* 3.55 Gears {Open-Rear}
Note: 3.36 Gears {Open-Rear} with the Turbo Hydra-Matic
Options
Both cars relative in cost............
