Old 06-10-2013, 09:45 AM   #1
4speedracer
Liked 10 Times in 6 Posts
Default 390-428 id numbers
I have a fe in a 63 galaxie not original engine, when pulled air cleaner has ford
factory holley numbers c80f-9510c list 3795-1 and intake c8ae9425-a. Where are the numbers to id the block? Owner said engine came out of a 68 Torino and has not been into since. thanks jamie
4speedracer is offline   Reply With Quote
Old 06-10-2013, 11:27 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: 390-428 id numbers
look at the right rear or the passenger side of block above where the starter mounts --block should be cast with either C8AE- A or -C or -E will be for a 1968 390 CI engine carb is for a 68 390 CI 4 speed Mustang/Cougar/Montego/Fairlane/Torino 600 CFM car
