Old 06-09-2013, 10:32 PM   #1
brent flynn
brent flynn's Avatar
Default Radial Tire question...
Anybody out there using a the Pheonix 9x30 92'' Radial, or the M/T 29.5/9 Drag radial? I know alot of you are using the Hoosier's... Reason im asking, is , these tires are 92'', and i have tire clearance probs with a 94'' ... I know Randi Lyn Shipp is running the M/T, but dont know if its the 92'' or 93'' version. My outer wheel well lips are trimmed, and on 10'' rim, i have 94'' pheonix bias tires on it now, and nothing but problems, in the pits, not down track... Im thinkin about goin with the M/T 29.5 Radial... Any thoughts? THanks!
Old 06-09-2013, 11:05 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Radial Tire question...
Radials don't grow like bias ply, so the same size radial may work well. Hoosier has 92.5" and 94" circumference radial slicks. Don't know about the other brands.
http://www.hoosiertire.com/specdrag.htm
Old 06-09-2013, 11:09 PM   #3
Dave Ribeiro
Liked 56 Times in 27 Posts
Default Re: Radial Tire question...
Brent,
Hoosier has 92.5" & 94 " dia ... ( 92.5 is what most people run )....
Dave Ribeiro 1033 STK
Old 06-09-2013, 11:17 PM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
advised you over a year ago to stay with a bias slick unless your car works on a junk starting line and if going with a radial slick buy Hoosier.
I ran the 92.5" Hoosier radial for 9 years, going through 27 pair and have been as quick as 1.28 in 60 foot at 3880 lbs.
IF you elected to run radials, remember no rim screws and no tubes.
Old 06-10-2013, 12:23 AM   #5
Tom Moock
Liked 10 Times in 6 Posts
Brent, I think you will have more sidewall clearance with Hoosier slicks over the M/T`s, on the same size wheel. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 06-10-2013, 09:16 AM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
X2...Listen to Myron. Hoosier radials are awesome. I wouldn't go back to bias ply slicks if they gave them away. An easy tenth quicker and they drive better down the track to boot!
Jim Kaekel 3836 STK
Old 06-10-2013, 09:38 AM   #7
1320racer
1320racer's Avatar
I've made more passes on radial slicks than most running stock eliminator. A tenth is the number you usually hear on small block cars but you won't see that on big block cars.
Old 06-10-2013, 11:18 AM   #8
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
You can find the M/T tire guide info here: http://www.mickeythompsontires.com/s...m=ETDragRadial
They have two different 30x9 radials, one taller, one wider. I always ran the 3066R (shorter 93", but wider, true 9" tire). 110 passes like clockwork, prints tickets, and was .12-.13 faster than the bias plys. Won a Bracket Finals, World Footbrake Challenge, and a Stock World Championship on these tires.
Only ran the 29.5x9's through one set. Also a good tire, but the 3066R's just fit my gearing better, and liked the extra tread width insurance.
Old 06-10-2013, 12:45 PM   #9
brent flynn
My car does consistent 1.48 60fts with an overcammed bracket
engine. My tires don't rub, down track, just around corners, forward or backward. I thought I'd give the 29.5 Mickey's a try, because they would give me a gear between. 4.56 and 4.88...and figured they would hook just fine,as long a track was good. I bought bias, last year, before my front suspension was redone, with global west stuff. I figured radials wouldn't work too well, with factory stuff. My car seems to work pretty good,,and I think it'll work even better, with more converter and gear.
Old 06-10-2013, 12:46 PM   #10
Ed Wright
Ed Wright's Avatar
I agree. One of the best moves I made was to MTs. Tried bias tires also for the local bracket track prep. Didn't hook as well as radials. I think the "bias better on junk tracks" story is out of date. Other SS cars around here found the same thing. They just use them to slow down.
Another was to Santuff shocks.
Ed Wright 4156 SS/JA
