Old 06-09-2013, 04:05 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Weather and performance
How much ET change do you guys see based on weather ( using the same track ) from the best air to the worst?
Using the quarter mile.
I'd like to know if a tenth (or so) is average , from one end of the "spectrum" to the other.
Old 06-09-2013, 06:22 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Weather and performance
good bracket door cars on gas here in the NE will swing 3 tenths, 3 MPH and .05 in 60 foot from best to worse over a season at the same track with no tuning changes.
Old 06-09-2013, 07:08 PM   #3
joespanova
Thanks Ed
I saw a 2.5 MPH swing from April in just the eighth! About a MPH in the quarter.......same pass..I lost a tenth in the eighth and about .15 over the quarter. I may have something else going on......springs , clutch......not sure yet.
Old 06-09-2013, 07:28 PM   #4
1320racer
1320racer's Avatar
stick cars ain't my thing but If I can be of further help just ask here or email.
Old 06-09-2013, 07:47 PM   #5
joespanova
Thanks
Old 06-10-2013, 09:06 AM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
I would say .30-.35 here in the midwest.
Jim Kaekel 3836 STK
Old 06-10-2013, 11:38 AM   #7
Jeff Lee
Jeff Lee's Avatar
Having a weather station is crucial. Not only for ET prediction but to tell wether or not changes you make to the vehicle are positive or negative and weather is not skewing your results. It will also help with determining if your having me handicap issues.
Jeff Lee 7494 D/S '70 AMX
Old 06-10-2013, 05:40 PM   #8
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
A tenth would not be unusual. a 1500 ft. of air change will move most gas cars a tenth. It's like a 20 degree temp change, a big moisture change or a big pressure change would have a similiar effect. On a race weekend it would be unusual to see a tenth change but from March to June in Louisiana would be a tenth or more of change. Going from 50 degree or so to 80,90, 100 degrees with the resulting moisture and pressure change could move a car 2 or three tenths. Dallas this year was very good air, close to zero or low hundreds. When the temps heat up the air density will rise to 3 or 4 thousand resulting in three tenths of et change.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 06-10-2013, 05:48 PM   #9
joespanova
Thanks for the replies!
Old 06-11-2013, 08:35 AM   #10
tj310
This is the site I use * http://www.dragtimes.com/da-density-...e=Calculate+DA * I spent some time there and made up a sheet I refer to. ---Trevor
