Can crankshaft harmonics/vibrations cause anything to happen in the valve train?
Art Leong 2095 SS |
Liked 1,583 Times in 582 Posts
I'm wondering if harmonics had a hand in my rocker to valve wear.
That is another thing that seems to be specific to my motor. Others have run same cams and springs trouble free.
Art Leong 2095 SS |
#4 | |
I believe that a crankshaft with counterweights and the right harmonic balancer will solve a lot of your problems. |
#5 | |
My other motor with less cam, less compression, and a stock crank. Responded to rpm a lot better than this motor. It was half a second between bracket mode and race mode. This motor was only two and a half tenths. That's shifting 1000 rpms short and running taller tires. It might go quicker with the stock crank.
Art Leong 2095 SS |
#6 | |
Nevertheless, if you want to get the best out of the crankshaft, I would suggest your crankshaft to have some weight removed and probably change the shape of the counterweight and have the lightening done properly. My choice and recommendation is Shaft Tech: http://www.shaftech.com/modification.html |
