When i apply the trans brake the car moves forward I now that i can run it to the line lock but what the car does when it's goes on the brake the nose of the car is still rocking up and down when i release the button. (run pro tree /stock front end 2 1/2 inch travel) Do i need to tighten the front end or the shock or will the linelock take care of this? Thanks for any help
Liked 858 Times in 234 Posts
The line lock will help with keeping the roll at a minimum, but I'd go after the cause of the roll.
Is this a PG with helical gears ? could be too much end play, lo line pressure ,or a slow or sticky solenoid. TH400/ 350 ,you need the line lock. If you have bump and rebound adj. on the front shocks tighten the bump a little, that will slow the dive a little.
