Old 05-11-2013, 10:40 PM   #1
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Drive line issues:
Gotta question. My 68 Chevelle wagon, 5.57 gears,350 trans, 327/245 horse,went with me to Irwindale for Summit last weekend. Third pass, the rear end failed. I got the car off the track OK, but about six teeth in a row failed on the ring gear. I put a spare set of 5.38's in it, car's together again, but Tony Janes wants me to pull the 350 out and check it for a bad sprag. Which sprag would have failed? The car seems to move in gear fine, I'm not sure if ring gear failure two feet off the line really would hurt it, but the trans comes out next weekend for a look(it leaks anyway, so we were going to reseal it),have any of you ever damaged a trans doing that? When I blew an engine at the end of first gear about two years ago, it rolled the sprag in the converter,which we had fixed, but that was a Powerglide. This three speed is kind of a different animal.Talking about animal, you should see this car leave!
Old 05-11-2013, 10:48 PM   #2
Dickens
Liked 12 Times in 8 Posts
Default Re: Drive line issues:
Hi Greg
I would recommend a call to Leo G. on the tranny stuff.
How did the 5.38 compare to the 5.57? Just curious.
Thx
DD
Dickens is offline   Reply With Quote
Old 05-12-2013, 10:15 AM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
You would want to check the Lo Roller clutch, that is part of a support that is splined into the case close to the gearsets. A nice upgrade is to replace the support and roller clutch with one from a late model 4L65-e .
Old 05-12-2013, 04:02 PM   #4
Greg Reimer 7376
Originally Posted by Dickens View Post
Hi Greg
Thx
DD
I haven't run the car with 5.38's yet. 5.57's are only 3-4 % lower, so I imagine putting radial tires on the car would compensate for 5.57-bias ply tires . I did run the car in the 1/8th with bias ply-5.57's and then put the radials on and picked up .05. Tony Janes owns the trans so it probably will go to someone like Leo.Meanwhile the Powerglide and converter go back in.
