Old 05-08-2013, 11:25 AM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Loose boosters in carb
Does anyone one have a fix for loose press-in boosters? I found all 4 loose. Carb is a Holley 4180.
What is the going cost to have this fixed, and who to send it to?
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 05-08-2013, 12:01 PM   #2
FED 387
Liked 329 Times in 177 Posts
Default Re: Loose boosters in carb
if they are not "too loose" you can try a little JB Weld to hold them in place--- otherwise most any of the REPUTABLE Holley rebuilders can fix that---they use a special 4 prong tool to stake them in place--- really they probabley need to be removed and machined flat (true) before they are staked so as to have a perfect mating surface!!!-- any RACE Carb guys in your area---??? no idea on cost tho
Old 05-08-2013, 12:15 PM   #3
Charlie Yannetti
Liked 192 Times in 83 Posts
David Cook at DC Carbs.. fair, honest, quick turn-around, great stuff..
Charlie Yannetti is offline   Reply With Quote
Old 05-08-2013, 12:27 PM   #4
t.tosto
Liked 62 Times in 23 Posts
Sean, call Tony Tosto@ 314 660 5684, might be able to help.
t.tosto is offline   Reply With Quote
Old 05-08-2013, 05:39 PM   #5
jmarkaudio
BLP in Orlando. Or if you are close to Orlando I have a swedging tool..
jmarkaudio is offline   Reply With Quote
Old 05-08-2013, 08:34 PM   #6
Don Anderson
Liked 24 Times in 8 Posts
Sean, give Bob Oliver a call: 775-331-5609
Don Anderson
M/S 5342
Don Anderson is offline   Reply With Quote
Old 05-08-2013, 11:27 PM   #7
Sean Marconette
Thanks for the replies. I am pulling my old carb out and will see how it performs. The carb with the loose boosters will go on the shelf for now.
Sean
Sean Marconette
84 Mustang
5060 SS/N
