Old 04-25-2013, 11:02 AM   #1
JRyan
Liked 112 Times in 31 Posts
Default 68 GTO cam specs
Just wondering if anyone has the old NHRA cam and spring specs for a 68 GTO 400/350 4 speed. I bought one to restore and thought it would be fun to build it around the old stocker specs.
Rick Ryan
Old 04-25-2013, 12:00 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: 68 GTO cam specs
try wallaceracing.com--- they race all kinds of Pontiacs has cam specs on their website might ask em about your spring questions--good luck
Old 04-25-2013, 12:39 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Rick Ryan
You can check on NHRA that has all the cam spec in the Engine section.
Pontiac did not use a lot of lift on their cams, mostly in the .401 to .421 range.
Even the RA4 was only something like .475
Old 04-25-2013, 01:32 PM   #4
JRyan
NHRA has the lift specs but they don't have the duration and overlap specs which is what I'm looking for.
Old 04-25-2013, 01:35 PM   #5
71lemans
Cam number 9779067
Name:	1968 Pontiac cam specs.jpeg
71lemans is offline   Reply With Quote
Old 04-25-2013, 03:11 PM   #6
FED 387
SPECS FOR CAM # 9779067
INTAKE
Dur 273
CL 112
Rocker arm lift
1.5---.407
1.65--.447
OVERLAP 54
EXHAUST
Dur 289
CL 113
SAME ROCKER SPECS
Old 04-25-2013, 03:17 PM   #7
JRyan
Thanks guys that's what I was looking for.
