04-02-2013, 11:11 AM | #1 |
Liked 2 Times in 2 Posts
Question about minimum weight
If you run a 67/68 mustang coupe in D/SA with a 390 what is the minimum weight
04-02-2013, 12:43 PM | #2 |
Liked 3,003 Times in 656 Posts
Re: Question about minimum weight
3238
James Williamson W200 J/SA |
04-02-2013, 12:55 PM | #3 |
Liked 56 Times in 21 Posts
1967-3200
1968-3165
Vic Guilmino 1129 STK |
04-02-2013, 01:57 PM | #4 |
Liked 952 Times in 263 Posts
Also, keep in mind there are different HP factors between the iron and Edelbrock heads. I also believe that the 68 can not use the aluminum intake and larger Holley carb that the 67 is allowed.
04-02-2013, 05:52 PM | #5 |
Liked 87 Times in 19 Posts
Aluminum heads weight with driver
1967 3277 1968 3239
Rusty Gillis Former NHRA SS/FA and SS/GA record holder |
04-02-2013, 09:23 PM | #6 |
I did the aluminum heads but you are correct I failed to round up.
04-03-2013, 01:21 PM | #7 |
NHRA will allow you to round DOWN to the nearest 5#'s.
So you would show 3275 or 3235 on your weight stickers.
Jeff Lee 7494 D/S '70 AMX |
