Old 03-25-2013, 10:32 AM   #1
Chuck Garey
Liked 10 Times in 7 Posts
Question VDO Tach repair
Any recommendations on a repair facility for VDO Play back Tach?
Chuck Garey is offline   Reply With Quote
Old 03-25-2013, 10:55 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: VDO Tach repair
ya might try Ronnie Smith--- I think he comes on here from time to time--Either he or his dad used to work for VDO might be able to help you
Old 03-25-2013, 03:37 PM   #3
Jim Kaekel
Liked 535 Times in 110 Posts
What's wrong with it? I've had one of those for years and love it. You do have to re-calibrate it once in a while, but it's fairly easy to do.
Jim Kaekel 3836 STK
Old 03-25-2013, 04:30 PM   #4
FED 387
Nichols Speedo & Instrument, Greensboro NC---
Old 03-25-2013, 04:57 PM   #5
Chuck Garey
Thanks for the info, Jim it doesn't come on at all. Seems dead?
Old 03-25-2013, 05:38 PM   #6
Ronnie Smith Jr
Ronnie Smith Jr's Avatar
I'll reach out to Dad and see if he knows of someone or somewhere to have it repaired.
Ronnie Smith Jr is offline   Reply With Quote
Old 03-25-2013, 06:52 PM   #7
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
You do know that you need an off/on switch so when you turn off the ignition above (I think it's 3000RPM's) it will reset to zero. You can turn the tack off with the switch and it will reset. I love mine and I bought a second one for my second car. Make sure that you put tin foil aroung the wires, it doesn't like outside interefence.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 03-26-2013, 08:46 PM   #8
Ronnie Smith Jr
Dad was told that National Speedometer in Charlotte repairs them. However, I did a quick Google search and could not come up with an address or web email for them. I did see a result for them in Las Vegas. I presume they are one and the same.
Hope this helps.
Old 03-27-2013, 10:39 AM   #9
Chuck Garey
I'll check out these leads
