Old 03-21-2013, 10:11 AM   #1
Rick Unterseh
Rick Unterseh's Avatar
Liked 31 Times in 7 Posts
Default TH350/ Metric 200 fittings
Does anyone know the size of the fittings in the TH350 and Metric for the fluid lines? I need to order the fittings and lines, but I'm at work in the cube farm, and obviously don't have the transmissions close.
Thanks in advance,
Rick
Rick Unterseh
O/SA
P/SA
Rick Unterseh is offline   Reply With Quote
Old 03-21-2013, 10:23 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: TH350/ Metric 200 fittings
I'll bet money if my memory is not failing me it's a 1/4" NPS thread--that's 1/4 inch NATIONAL PIPE STRAIGHT----- not NPT which is NATIONAL PIPE TAPERED---FED 387
Old 03-21-2013, 01:37 PM   #3
FED 387
Actually after thinking this over you need a 1/4-18 NPSF fitting---NPSF is a Dryseal American Standard Straight Pipe Thread--means no sealer required usually it is used with fuel/oil lines --hope this helps --FED387
Old 03-21-2013, 03:13 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Just did a Metric install ,definetely 1/4" straight.
