Old 03-20-2013, 09:54 PM   #1
Paul Ceasrine
Liked 10 Times in 10 Posts
Default 1968 Chevelle
1968 Chevelle
Models
* Chevelle 300
* Chevelle 300 'Deluxe'
* Chevelle Malibu
* Chevelle Malibu 'SS 396'
* Chevelle Concourse Custom Station Wagon
* Chevelle 4-Door Station Wagon
Total Models = 15
Performance Engines
* 327/275 HP
* 327/325 HP
* 396/325 HP
* 396/350 HP
* 396/375 HP
1968 NHRA Classes for the Sports Coupe
* 396/375 HP.........B/S or SS/E
* 396/350 HP.........E/S or SS/F
* 396/325 HP.........F/S
* 327/325 HP.........E/S (4-Speed Only)
* 327/275 HP.........I/S
Old 03-20-2013, 10:30 PM   #2
Paul Ceasrine
Default Re: 1968 Chevelle
1968 'L-79' 327/325 HP
Production Numbers......4082
* 4-Speed Only
* Compression Ratio............................................. 11.0 - 1 (Domed Piston)
* Camshaft (Hydraulic) - {'151 Cam'}.................. .447" Lift / 290* Duration {222* @ .050 Lift}
* Cylinder Heads #3217291 - {'291 Heads'}...... 2.02" Intake / 1.60" Exhaust
* Rochester Quadra-Jet........................................ 750 CFM
* 12-Bolt Rear
* M-20 {Wide-Ratio}
* M-21 {Close-Ratio}
* KK Code................................... 4.10 Gears
* KM Code....................................4.56 Gears
* KO Code................................... 4.88 Gears
Old 03-21-2013, 06:29 AM   #3
Paul Ceasrine
Rico,,,,,,
The shipping weights.
* Chevelle '300' w/ 327/275 HP...............................3250 lbs.
* Chevelle '300' Station Wagon w/ 327/275 HP....3550 lbs..
* Malibu 'Sports Coupe' w/ 327/275 HP.................3305 lbs.
* Malibu 'Sports Coupe' w/ 327/325 HP.................3310 lbs.
* Malibu 'SS 396'.............................................. .........3510 lbs.
* Convertibles...{Add}...+60 lbs.
* Automatics.....{Add{....+31 lbs.
