Old 03-16-2013, 12:25 PM   #1
Marty Knox
Liked 44 Times in 19 Posts
Default Front Wheel Drive - Final Drive Ratio
I am wondering what you do on a FWD car to change the final drive ratio. On a rear wheel drive you change the rear gears - what can you do on a FWD? Don't some have chain - can you change the sprockets?
Marty Knox 3071 STK
Marty Knox is offline   Reply With Quote
Old 03-16-2013, 08:04 PM   #2
Bob Shaw
Liked 295 Times in 60 Posts
Default Re: Front Wheel Drive - Final Drive Ratio
Yes
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 03-18-2013, 01:36 AM   #3
Liked 5,080 Times in 1,936 Posts
Marty, the GM T125 and T440 (and electronic versions ) use different final drive planets, combined with different chain drive and driven sprockets to attain a variety of ratios.
You can put together a 3.73 final with factory parts.
... Don't know about Ford and Chrysler.
Old 03-18-2013, 07:11 AM   #4
DonatoEng
Liked 8 Times in 5 Posts
The Chrysler 3sp autos had several different FD ratios and transfer gear sets to mix and match. Also some aftermarket transfer gear sets were made.
DonatoEng is offline   Reply With Quote
