Old 03-13-2013, 09:53 AM   #1
FLEMING
Liked 55 Times in 26 Posts
Default What grease are you using for bushings on your caltracs?
I am installing the calvert stuff and was wondering what grease you are using on front and rear spring eyes
FLEMING is offline   Reply With Quote
Old 03-13-2013, 03:17 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: What grease are you using for bushings on your caltracs?
None. Grease is a magnet for grime.
Jeff Lee 7494 D/S '70 AMX
Old 03-13-2013, 09:43 PM   #3
Tex013
Liked 43 Times in 25 Posts
i use a light smear of copper grease on the aluminium bushes.
Tex
Tex013 is offline   Reply With Quote
Old 03-14-2013, 05:33 AM   #4
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
i'll be following this....i just ordered mine tuesday...
prolly should have asked 'em when i had 'em on the phone
Old 03-14-2013, 08:34 AM   #5
FLEMING
Alex told me to use a good synthetic wheel bearing grease so thats what I will use, also i have been told not to tighting the front spring and rear spring bolts to tight.. Install has been very straight forward so far.. I just wish I knew wether to put a degree shim in or not to start off with to get my pinion angle right. LOL no big deal to take it apart and stick one in.. Aluminum and steel together I am for sure going to use something good..
