Old 02-19-2013, 09:41 AM   #1
philbilly
philbilly's Avatar
Default Vinyls Numbers??
Where does a feller find the numbers that go on the inside of the windows. For instance . Allen Wades super stock camaro has some awesome lookin vinyls.
philbilly is offline   Reply With Quote
Old 02-19-2013, 10:36 AM   #2
Chad Rhodes
Default Re: Vinyls Numbers??
You just run them mirror reverse. It's not that hard. What did you have in mind?
Chad Rhodes 2113 I/SA
Old 02-19-2013, 10:40 AM   #3
philbilly
philbilly's Avatar
Chad I just like the looks of them I like the way his name is in a script and the numbers are not to big and bulky . wades numbers are just about the right idea size. Do you do the vinyls?? chad?
Old 02-19-2013, 10:40 AM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Michael Beard
Sean Marconette
84 Mustang
5060 SS/N
Old 02-19-2013, 10:40 AM   #5
JRyan
Liked 112 Times in 31 Posts
Glen Demenge. Glen's sign dezine McGregor, Mn does some really nice ones. I believe his number is 218-426-4009.
Old 02-19-2013, 10:48 AM   #6
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
X2 on Michael Beard. He did mine and I'm very happy with them!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 02-19-2013, 11:08 AM   #7
Dennis P Chapman
Liked 53 Times in 25 Posts
Steve Bell in NJ.
Dennis P Chapman 1904 STK
Old 02-19-2013, 11:14 AM   #8
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Thumbs up Re: Vinyls Numbers??
Try this
nhranumbers.com
This place will make full color printed vinyl numbers that mount on the inside of the glass.
And they look COOL! no stacking 1 piece.
Also offer chrome with color outline.
MEXJOE is offline   Reply With Quote
Old 02-19-2013, 11:23 AM   #9
philbilly
philbilly's Avatar
Lew
beards done numbers for me for years.. not like the ones I am wanting atleast he hasnt chimmed in. he might be mad at me still But theres someone out there that does it.
Old 02-19-2013, 11:24 AM   #10
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
I specialize in full color printed vinyl, and those you can't do as inside application, as the adhesive side is solid grey. In order to do inside numbers, you need to use standard vinyl that the same color on the adhesive side as it is on the outside. To get that look, you'd cut two separate decals (backwards) and stack them. Seeing it through the glass gives it a little more of a painted look. I used to do them when I had my physical sign shop, but I no longer have a cutter in-house. I work with a partner to handle the actual printing and shipping. We keep so busy with the full color printed stuff that something like that is now considered 'special order'. You should be able to get it done at any standard local decal shop.
