Old 02-16-2013, 10:53 PM   #1
KURT GROSS
Default Does JW Bell require using smaller flexplate?
Need advice please!
I have a 1970 Nova, 350/TH200. The TH200 and convertor are new, and the case has the JW Bell bellhousing. The old TH200 had a stock case. It sure looks like i need to switch flexplates from my current 168 tooth to the smaller 153. The flexplate to bellhousing clearance is really tight inside the JW Bell and i just can't believe it should be that tight. I hope someone on here has "been there done that" and can give me some advice.
Thanks for any help or comments.
Kurt Gross
2001 Division 6 S/ST Champion
2002 Jegs Allstar
2010 Woodburn Dragstrip S/P Track Champion
KURT GROSS is offline   Reply With Quote
Old 02-17-2013, 02:39 PM   #2
vsrc
Default Re: Does JW Bell require using smaller flexplate?
i have had some older jw bells that were very close, had to put in my mill and clearance . as far as i know 200s were all based around 153 but you would think the aftermarket would support either combo, call jw, ask for john or tracey.
vsrc is offline   Reply With Quote
Old 02-19-2013, 11:06 PM   #3
KURT GROSS
Thanks vsrc, and you were correct. It fits but is tight. It is designed to accept both sizes. At first it sure looked like no way but it works.
Kurt
2002 Jegs Allstar
