Old 02-15-2013, 10:33 PM   #1
NewHemi
NewHemi's Avatar
Default 2009 Dodge Challenger Drag Pak #24
For Sale, The Infamous Dodge Challenger 2009 Drag Pak #24
The "MegaManiac" is for Sale for $73,000 with 24 foot trailer.
Here is what is included in the Sale
2009 Challenger Drag Pak #24 Turnkey Ready To Race with 5.7 Engine Combination campaigned as a 2010
The car has been built with the lightest available legal components and is one of the lightest DP Cars ever built.
Arguably this car is the most successful, and most highly publicized of all of the Challenger Drag Paks.
The Car.
The Cage and Chassis work were done by Mike Pustenly at MPR Race Cars in Michigan , undoubtedly one of the premier chassis builders in the country period. So much so that when Dodge, Ford AND GM decided to build the new "Package Cars" He was selected by ALL to do the prototype work !
The car is #24 of 100 2009 Challenger Drag Pak's built, IF You know what one is then you already know they have Carbon Scoop Hood, Viper Seats, Polycarbonate (included, but replaced with Glass) side windows, a lightened chassis with 3100lb factory weight listing.
This car, the MegaManiac has had complete chassis paint underneath , trunk and engine compartment. A polished diamond plate rear firewall.
The exterior is still the factory B/C in white, and the entire current scheme on the car is a WRAP and Easily removed to show a white clean car ready for your wrap or Paint Scheme !
NOTE: the original hood is also included and wrapped, but damaged. The replacement hood is painted black. And instead of the inherent problems Dzus fasteners, this new hood has chrome push button Quik Latches (NHRA approved) for ease of removal and installation,
This car also has the following features.
  • Moser "Drag Pak Special" Custom 8 3/4 housing with Richmond pro gears, and Strange alloy spool with Aftermarket Yukon Nodular case, and billet caps and adjusters.
  • Custom built 904 Transmission, Alloy internals , E-Shift Valve Body, Custom
  • ATI custom stall Converter
  • Turbo Action Shifter, with Command Center and E-Shift Computer, Line Lock
  • Alloy Custom Driveshaft with Mark Willams Yokes
  • Aeromotive fuel system, pump, valves, Regulator, Check Valves etc.
  • All AN Braided throughout.
  • Custom Bogart Alumilite Wheels with Hoosier tires
  • Mark Williams Front Brakes and stock hubs have been replaced with Strange hubs and brakes.
  • Strange Double adjustable front and rear shocks
  • Wilwood rear brakes.
  • Lightweight alloy removable steering wheel (column is tilt/telescope)
  • Dual front pusher fans
  • 16Volt Powermaster alternator and battery with 16V charger
  • Positive custom window switches eliminate problems with "factory" windows and switches
  • Chrome Electric Water Pump
  • CSR Fiber Trans Shield.
  • Custom 3 Step Headers with merge collectors
  • FAST ECU with custom tune
  • INNOVATE Exhaust Gas Temperature system
The Engine.
  • 5.7 Drag Pak Motor, in car running, fresh. Max legal bore, Max legal stroke.
  • Heads by Heads Up.
  • Custom Cam grind.
  • Engine found perfectly legal in three teardowns.
The Other.
24ft Carmate trailer (1997) serviced, cosmetically fair, this trailer has two new axles and has hauled our car across the country over 12k miles!
Setup to pull Drag Pak and Spares, .
Newer Breakaway Switch and Battery
Load leveler bars and hitch.
Accomplishments.
  • 2011 NHRA National Stock Automatic Performer winner
  • NHRA A/SA record for speed and ET in Nov 2011
  • Best Appearing Car 2011 Denver Mopar Nationals
  • Numerous Class wins
  • Stock Eliminator in Oklahoma
40 different things.
Lots of additional (legal) features. modifications to make racing easier, or the car run faster and more. I have actually counted more than 40 things we did first, or that others still don't know about. Feature list disclosed to purchaser upon completed sale.
If you want a consistent winner.....
If you want the most innovative Drag Pak...
If you want a peice of history....
Let's talk. Just give me a call... PM me for phone number.
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 10-17-2013, 09:35 PM   #2
Stephen Bell
Default Re: 2009 Dodge Challenger Drag Pak #24
I'm sure this car sold, but looking to find a Drag Pak. Please call if you have any information. 318-272-5792 Thanks, Stephen Bell
Stephen Bell is offline   Reply With Quote
