Old 01-29-2013, 02:15 PM   #1
Darrin Christen
Darrin Christen's Avatar
Default Rear cam plug for 184 bowtie block
I'm looking for a part number for the rear cam plug in a sbc 184 bowtie block. Are they available from the mail order chains? Thanks
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 01-29-2013, 04:33 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Rear cam plug for 184 bowtie block
not sure but you might try a BBC rear plug otherwise I believe most SB2 blocks use 58MM/ 2 inch diameter cams-- also go to a auto parts store that has a good selection of freeze plugs and go thru all of them see if ya can find one that fits--- also might try truck or farm tractor places too
Old 01-29-2013, 06:00 PM   #3
ron mattson
Liked 67 Times in 30 Posts
I think the dorman number is 555-069 for the shallow cup style.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 01-29-2013, 07:28 PM   #4
Ed Wright
Ed Wright's Avatar
The black bolt-in piece? PM me your shipping info and I'll send you one. Should have gotten one with the block.
Ed Wright 4156 SS/JA
Old 01-29-2013, 08:53 PM   #5
Darrin Christen
Thanks Ed, it's not a bolt in piece. It's a shallow freeze plug type. Jegs has one listed for the Dart blocks that looks just like the one in my bowtie block. I'm not sure if they are the same diameter though.
Old 01-29-2013, 09:17 PM   #6
Ed Wright
Ed Wright's Avatar
My Bowties came with a black aluminium plate with an O ring, two small ears for retainer screws, and the Bowtie emblem etched on it.
There aren't two small screw holes next to the cam bore?
Old 01-29-2013, 10:25 PM   #7
Darrin Christen
Ed, I'm not sure about the bolt holes. I should have the block back from the machine shop at the end of the week. I'll check and let you know. Thanks
Old 01-30-2013, 01:47 PM   #8
BillK
Liked 30 Times in 17 Posts
Darren,
Why not just have the machine shop measure the hole and see if they have the correct plug, if it does not use the plate that is. I keep almost every size in stock and would probably give you one if I was doing the block.
Bill Koustenis
BillK is offline   Reply With Quote
Old 01-30-2013, 02:21 PM   #9
Darrin Christen
Originally Posted by BillK View Post
Darren,
The block is already crated up and on its way back to me. I'm sure if I call them they would know which one is needed. I was placing an order from Jegs and wondered if it was something they may stock is the reason I asked the question here. Thanks for everyones help.
Old 01-30-2013, 04:42 PM   #10
Ed Wright
Ed Wright's Avatar
Daren, if it has stock size cam journals, and it turns out to have those two threaded holes, this factory piece is a nice heal. It's like a plug with an O ring, made on a flat plate with ears for the two screws. Slicker piece than a drive-in plug. I can't use it because I had 50mm roller cam bearings installed. The hole is too big now.
