Old 01-27-2013, 09:05 PM   #1
Mark Faul
Liked 43 Times in 9 Posts
Default T350 help
Hopefully someone has some ideas about a tranny issue. Had to do a new case over the winter. My guy transfered all the guts over and had to replace the valve body gaskets. Said he copied them exactly. Started the car for the first time yesterday, and moves great in reverse and low. Nothing in 2nd or 3rd. Tranny guy came over today, and checked pressures. 200lbs at all 3 ports. Took it all apart, and air tested on the bench. Everything checked and looked great. Changed stator anyway just because he brought one. Still no good. It's locked so bad in 2nd and 3rd you can't turn the tires.
Help please!!!!
He's calling Hipster tomorrow (transbrake manufacturer). Do they have a special valve body gasket? Anyone ever run across this?
One more thing. The converter was just freshened. But there's nothing in the converter that could cause that, right?
Thanks a lot!
Mark
Mark Faul is offline   Reply With Quote
