Old 01-23-2013, 12:01 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Bump steer on Fox body Mustang
Does anyone have any thoughts if the bump steer kits are needed? Replacing front tires and the old ones are worn badly on the inner area. Center and outer area is fine. Going to realign. Camber caster plates and struts have not moved as I marked them.
Thanks
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-23-2013, 12:48 PM   #2
Notch1320
Default Re: Bump steer on Fox body Mustang
I run a kit on my car and have had no issues with tire wear. I think it was from Maximum Motorsports.
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 01-23-2013, 01:08 PM   #3
Sean Marconette
Thank You
Sean Marconette
84 Mustang
5060 SS/N
Old 01-24-2013, 05:57 PM   #4
Lee Jordan (3223) A/S
Lee Jordan (3223) A/S's Avatar
Liked 55 Times in 17 Posts
I agree. My 94 GT was wearing tires till I added the same kit. Works really good.
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car.
Lee Jordan (3223) A/S is offline   Reply With Quote
Old 01-24-2013, 09:42 PM   #5
Sean Marconette
Thank You.
OK another question, any preference on the bolt or the taper style?
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-24-2013, 10:00 PM   #6
Notch1320
I went with the "bolt" style for ease of maintenance on the front end. Easy to adjust, replace, inspect....
Shawn Allsup
K/S 718
