Old 01-21-2013, 11:19 AM   #1
Straightliner
Default Double entry....
What are guys doing to your setup to do double enter when the other class doesn't allow throttle stops? How are you satisfying tech and or the other racers?
Thanks.
Straightliner is offline   Reply With Quote
Old 01-21-2013, 09:38 PM   #2
Chuck Westcott
Chuck Westcott's Avatar
Smile Re: Double entry....
Call me stupid, but I don't understand the question !
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 01-22-2013, 06:26 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,252 Times in 989 Posts
Default Re: Double entry....
Think Straightliner is wondering about when racers double enter S/Pro and Pro or how many tracks are running 6.0, 7.0 etc (1/8 mi) and S/ST, S/G at the same event and certain classes dont allow electronics. I know some racers have easy boxes to take out for this reason or coil/stow wiring bundles to their boxes/throttle stops. Personally I wouldn't like to run an opponent who simply "unhooked" his electronics but there are tracks that allow it.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-23-2013, 01:02 PM   #4
Straightliner
Yes I mean 10.90 with throttle stop and Super Pro with delay box but throttle stop is not allowed. I guess it's really not feasible, so I imagine you only double enter when Super Pro also allows throttle stops. I still wanted to pose the question in case someone has a trick setup!
Thanks
Old 01-23-2013, 01:54 PM   #5
Glenn Quinn
Glenn Quinn's Avatar
If I understand correctly, you do the same thing I do. When I run SP, I just remove the TS wire from my 450 delay box. When I run SG, I just put it back. No other changes are required, takes less than 20 seconds.
Glenn Quinn is offline   Reply With Quote
