Old 01-13-2013, 09:21 PM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Hoosier front runners...
Any "history" of them splitting/cracking all the way around the sidewall? (Mine have one season on them and are 28.0/4.5-15 I run 40 psi in them)
Old 01-13-2013, 09:48 PM   #2
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Default Re: Hoosier front runners...
I have the same tire. Run 40 psi also on 4400 lb car. No problems in 3 seasons.
Bob Bender 144 O/SA
Old 01-13-2013, 09:56 PM   #3
Run to Rund
Liked 56 Times in 29 Posts
Same tire, 35 psi, no issues after several years of use.
Old 01-14-2013, 09:22 AM   #4
Jim Kaekel
Liked 536 Times in 110 Posts
I've used that same tire for close to 10 years, never had a problem. Hopefully, it was just a defective tire.
Jim Kaekel 3836 STK
Old 01-14-2013, 10:01 AM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Cool Re: Hoosier front runners...
I have also used that tire without any problems ... Were they new &
did they sit outside ???
Dave Ribeiro 1033 STK
Old 01-14-2013, 01:27 PM   #6
Run to Rund
Keep them away from ozone sources such as electric motors.
Old 01-14-2013, 02:25 PM   #7
njk53
It depends also upon how to store them for the winter. I was told by Hoosier, both front and rear tires should be removed from the car, deflated, and stored in a cool dry place out of the path of any sunlight.
Nelson Kowal
Stock 345
Old 01-14-2013, 07:40 PM   #8
rallye bob
rallye bob's Avatar
Mine are stored on the car, full of air, off the ground, in a un-heated, attached garage.... very little, indirect sun light... Yes they were purchased new....
Old 01-15-2013, 07:50 PM   #9
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Where did you buy them from?
STK1217 is offline   Reply With Quote
Old 01-15-2013, 08:46 PM   #10
Run to Rund
I read, iirc on Hooiser's website, that tires should be stored with 5 psi and not allowed to freeze. While I don't reduce air pressure, I keep the garage temperature above freezing.
