Old 01-08-2013, 02:22 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Stick cars , tubes or no tubes
I just put some new rubber on my Nova and I'm thinking of ditching the tubes. I had 14-32 C07 Hoosiers , now have the 13.5 -31.5 same compound. The car may have liked the additional sidewall stiffness with the tubes and I know I liked the fact that they held air all the time..........however , any opinions?
Thanks
Old 01-08-2013, 04:18 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Stick cars , tubes or no tubes
Ditch'em you'll be glad
Mike Taylor 3601
Old 01-08-2013, 05:50 PM   #3
Jeff Colvert
Jeff Colvert's Avatar
Liked 3 Times in 2 Posts
Thumbs up Re: Stick cars , tubes or no tubes
Quit running tubes in 1980. Like taking 14lbs off your rear spinning or axle weight.
Jeff Colvert SS/G,F,GT/B 4456
Jeff Colvert is offline   Reply With Quote
Old 01-08-2013, 06:06 PM   #4
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
http://www.dragracingonline.com/tech...retubes-1.html
Eddies66 is offline   Reply With Quote
Old 01-08-2013, 06:44 PM   #5
Ed Wright
Ed Wright's Avatar
I quite running tubes in the early '70s. Got tired of pinching the tubes and having tires go flat between rounds. The old bias tires would sometimes pinch the tube at the launch. Carroll Caudle and I both had that happen about a week apart. We both ruined tires by the time we got our cars stopped. He was the first (between the two of us) to try it tubeless. His car also picked up ET & MPH tubeless. I changed over and picked up also. Those old Firestones would just about go flat during the week. My MT & Goodyear radials hold air just fine. Seldom loose any at all between races. The Hoosier radials I ran before didn't leak either. As much air as I run in my radials, I don't even run screws.
Had one of those guys that always seem to have a beer in their hand walk by once (had Hoosiers then) and tell me "You had better put screws in your wheels! Your tires are slipping on the wheels!" I didn't walk back to check, but asked him "Is the letter i in Hoosier lined up with the valve stem?" He looked and said "Yes!" I said "Dang! Must slip back to the same place every time!" Not sure he even got it. :-)
Ed Wright 4156 SS/JA
Old 01-08-2013, 08:36 PM   #6
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
I personally like the tubes on a stick car, like you said Joe stiffer sidewalls, they don't break down as quick. Its personal preference though. I've ran them both and literally have seen no diff in et myself. Your car may be different. I also like the fact of them not leaking down every 10 minutes lol. I guess if ditched the tubes and beadlocks I might have made INDY last year some guys say lol.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 01-08-2013, 08:53 PM   #7
joespanova
Thanks........I'm still confused LOL
Old 01-08-2013, 10:11 PM   #8
joespanova
Yeah , I hear ya ......I'm probably going to try no tubes.........I am leery about no screws though.
Old 01-08-2013, 11:20 PM   #9
Notch1320
No tubes here.... As for not wanting to run screws, many use Permatex HI-TAC on the beads or contact Weld an look into their Knurled Bead option.
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 01-09-2013, 12:03 AM   #10
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
No tubes
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
