Old 12-17-2012, 12:09 PM   #1
vic guilmino
Liked 56 Times in 21 Posts
Default Need help
Gen. Is showing. A code 3
Will not turn over
We are on the road
Vic Guilmino 1129 STK
Old 12-17-2012, 12:53 PM   #2
69Cobra
Liked 2 Times in 2 Posts
Default Re: Need help
Will not turn over
We are on the road
What is "Gen." specifically? Give me as much info about whatever it is and I'll see what I can find.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 12-17-2012, 01:03 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Vic,
Is this the generator in the coach? What make and model is the unit?
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 12-17-2012, 01:04 PM   #4
art leong
Try disconecting the power source for a couple of minutes. This might reset the codes.
Art Leong 2095 SS
Old 12-17-2012, 01:08 PM   #5
Lew Silverman
If it's an Onan -
SERVICE CHECK FAULT—CODE NO. 3(A second-level fault occurred)
Corrective Action: Check the second-level fault code by touching Stop.
See what the second-level fault is.
Lew
Lew Silverman #2070
Old 12-17-2012, 01:23 PM   #6
69Cobra
Could it be low on oil? Or not sitting level to where it thinks it low on oil?
Kris Rachford
C/S 3032
Old 12-17-2012, 01:30 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Vic,you must press and hold the switch on the generator to get the complete code.
The 3 or 33 code just tells you there are other codes present
Matt Schurman just repaired my Onan for the same problem ,it would run fine and then after being shut off it would not crank over to restart.
Had a code pertaining to the governer,altho it actually was a problem with the inverter section which is pretty much the brain of the generator.
Tom Goldman is online now   Reply With Quote
Old 12-17-2012, 01:32 PM   #8
vic guilmino
Oil is good
It is ever a 3 or 33
Old 12-17-2012, 01:58 PM   #9
Lew Silverman
Tom is right. Hold the STOP button to get the secondary-fault code -
Here's a link to what you may find -
http://www.alpinesocal.com/sitebuild...leshooting.pdf
Keep us posted!
Lew
Lew Silverman #2070
Old 12-17-2012, 02:19 PM   #10
vic guilmino
When I hold the shop button the light stays on
