Old 12-06-2012, 09:07 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default C19-CP pin locks and pins
What would be the correct pin locks to use on the C19-CP pistons?
Also, would the 0.090 wall tool steel wrist pins hold up in a 350/155/287 (1975) combo? It is the lightest pin I have found but I am not sure if it would hold up or if I should go to a slightly thicker wall pin.
Thanks in advance.
Chad
Chad E532 is offline   Reply With Quote
