Old 11-28-2012, 12:51 PM   #1
acme383
Default Fox Body Bumpsteer/Race Alignmet??
my brother has a 93 fox that he just replaced the K-member with a tube type. He installed camber plates and purchased a bumpsteer kit. He still drives the car on the street, but mostly bracket races the car. What Should I set the Camber and caster to? and at what ride height do I set the specs? 1" above ride height or more? How much bumpsteer is acceptable? How much shim is usually needed? starting point? Do you have to shorten the inner tier od length? Thanks in advance. Dan
acme383 is offline   Reply With Quote
