Old 11-26-2012, 12:38 PM   #1
Chris Hardy
Liked 4 Times in 1 Post
Default Gas Ported Top Ring?
Has anyone actually seen a gain from using these 2 piece, gas ported top rings vs Dyke or a good, backcut top ring?
Thanks,
Chris Hardy
RET
Chris Hardy is offline   Reply With Quote
Old 11-26-2012, 01:33 PM   #2
afret
Default Re: Gas Ported Top Ring?
I believe so. With the amount Total Seal charges for a set of rings with the ported spacers, I'm certain they have realized a significant gain to their bottom line. LOL
afret is offline   Reply With Quote
Old 11-26-2012, 01:58 PM   #3
Chris Hardy
That is exactly what I saw. Zero gain in HP. And Total Seal making dividends. Thanks
Old 11-28-2012, 10:25 PM   #4
Bub Whitaker
Yes Chris, I have seen a gain
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 11-29-2012, 10:24 PM   #5
Mike Fuller
Liked 198 Times in 79 Posts
Which rings did you try,the .047 or the .034?
Mike Fuller 396 STK
3961 SS
Old 11-30-2012, 09:18 AM   #6
Bub Whitaker
Both .047 (1.2mm) gapless most engines depending on max RPM and .032 (.8mm) have shown gains over all the other top rings we have tried here
Bub Whitaker
Old 12-06-2012, 09:08 AM   #7
Chris Hardy
Hi Bub,
Were you keeping your end gaps extremely tight on the engines that you are comparing these gas ring to?
Thanks,
Chris
