Liked 238 Times in 113 Posts
Just a question, how does a Tech Inspector measure the valve lift on a stocker, with a solid lift camshaft. Is it basically the same as the way they check a hydraulic lifter style camshaft ?
Thanks |
Liked 1,778 Times in 404 Posts
At the valve, with a dial indicator on the retainer, with 0.0" lash.
Alan Roehrich 212A G/S |
Liked 10 Times in 6 Posts
They pound a razor blade between the spring and the retainer and use a dial indicator on the blade to check lift. Tom
Tom Moock 5704 STK |
