Old 11-15-2012, 11:13 AM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default DA shock starting point
Just put some Strange DA's on the rear and I have no idea what settings to use as a starting point. 70 Nova, ladder bar, 125 springs, 2900 lbs with 1320 on the rear. Calvert 90/10 with Santhuff springs with a loosened up stock front suspension.
What's a good starting point?
Do you set the right shock a click stiffer on extension?
I was told the rear suspension looked bound up, so I took the mono leaf set up off and put the coil overs on. The video shows where I was.
Ron Gusack is offline   Reply With Quote
