Old 11-13-2012, 08:42 PM   #1
joe huestis
Liked 409 Times in 113 Posts
Thumbs up Question on 68-72 Olds type "O" Rear
when changing gear ratio in this type differential, do you need to change carriers like you do in a "C" type 12 bolt ? this is the 12 bolt cover with the 10 bolt ring gear. changing gear from a 3:42 to a 4:33. thanks !
Joe Huestis
Youngsville, NC
Old 11-14-2012, 12:55 AM   #2
Dan Lattimore
Liked 154 Times in 37 Posts
Default Re: Question on 68-72 Olds type "O" Rear
Joe, Same case they just made the ring gears really thick.
66W30POST
Dan Lattimore is offline   Reply With Quote
Old 11-14-2012, 07:30 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Joe;
I went from a 3:23 to a 4:66 (GM gears) in the "O" rear.... in my '70 f/85...
Old 11-14-2012, 11:54 AM   #4
Run to Rund
Liked 54 Times in 27 Posts
With OEM stuff, Olds parts had the same carrier for all "heavy duty" ratios, 3.42 to 5.00. The rear was used from late 1966 to 1970. The HD stuff wasn't readily available until 68; in 69 Olds went from 31 spline axles to 28 so the carrier side gears changed, of course.
Old 11-15-2012, 12:45 AM   #5
BobD
Glad to see this post! This is going to be interesting...
BobD is offline   Reply With Quote
Old 11-15-2012, 05:48 PM   #6
joe huestis
Thumbs up Re: Question on 68-72 Olds type "O" Rear
Thanks for all your responses. Danny, we are going to move forward on this project a little at a time. Fred installed a line-loc and drag shocks this past weekend. The gears are next. We are seeing how much we need to do to run a tad below the E/Pure Stk. index without drastically altering this pristine all origional muscle car. Only 13K origional miles on odometer !
Bob, I am anxious to see this through, I believe car has potential. When Fred had it at Piedmont last weekend, I was amazed at the folks coming over to check his car out. They walked right past mine and didn't bother ! LOL !!
Joe Huestis
Youngsville, NC
Old 11-15-2012, 06:52 PM   #7
Dan Lattimore
Smile Re: Question on 68-72 Olds type "O" Rear
Wow ! 13,000 miles ! Are you boys sure you want to do this ?
66W30POST
Old 11-15-2012, 07:14 PM   #8
joe huestis
Fred will not do anything to devalue this car. Better to have some fun with it rather than it sit in a garage to just look at.
Joe Huestis
Youngsville, NC
Old 11-15-2012, 08:56 PM   #9
Liked 5,143 Times in 1,964 Posts
Old 11-17-2012, 10:32 PM   #10
Fred Rice
Fred Rice's Avatar
Well it looks like I have procured a ring and pinion set.....
(picture for Mark...lol)
My question is ....as these are original GM pieces, will they fit the 3:42 carrier that is in the car now? I have 31 spline axles. I have heard of a spacer being needed on some of these applications.Would I need a spacer with a factory set of gears vs. aftermarket or visa versa? Just want to make sure before we dig into this..Any help on this will be appreciated.
Regards,
Fred
Fred Rice is offline   Reply With Quote
