Old 10-31-2012, 03:34 PM   #1
73pontiacventura
Default pontiac 400 build - what stock heads with slight upgrades
What pontiac heads to be ran on a 1970 400ci block now I have #17 castings , was being lead to #670 castings .That is my question for when I take the motor out of the x body ventura to look towards 11's at dragstrip 1/4 mile . I was told to come to this site from Yellowbullet most of them are motivated for edelbrock or kauffman aluminum heads - I am looking to save some coin to put other places too . http://www.yellowbullet.com/forum/sh...d.php?t=520441 Thank you for info to get me here .
73pontiacventura is offline   Reply With Quote
Old 10-31-2012, 04:06 PM   #2
gmeyer
Liked 35 Times in 16 Posts
Default Re: pontiac 400 build - what stock heads with slight upgrade
6X-4 or 6X-8 for low compression will work fine or a 16 head for hi compression motor
gmeyer is offline   Reply With Quote
Old 10-31-2012, 05:48 PM   #3
Jeff Goss
Jeff Goss's Avatar
Lots of help here!
http://forums.performanceyears.com/forums/
Jeff Goss is offline   Reply With Quote
Old 10-31-2012, 05:52 PM   #4
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: pontiac 400 build - what stock heads with slight upgrade
X2
* Listen to Jeff , this is a good site ... You need to set a budget on what you want to spend to go into the 11's ... You don't need alum heads , etc .. Check it out ...
Dave Ribeiro 1033 STK
