Liked 811 Times in 213 Posts
I run a Camaro Stocker w/ MSD 7AL3, electric water pump, electric fan & naturally the fuel pump.
I only use 1 12 volt battery, Is this enough for all of the items i just listed ??? Can you get by with 1 ( 16 volt battery) OR is it just better to use 2 ( 12 volt batteries )?? I forgot to mention, if its nite time racing i usually run the parking lites which includes the tach lite and the other gauges too. If you go to Two batteries, whats best to put on the front battery, & what would you wire for the battery in the trunk???? Thx for any help. |
