Old 09-16-2012, 08:36 AM   #1
bricki
Default Hoosier 29.5x11.5Wx15 tire growth.
Hi i am using Hoosier 29x12x15 slick but want to go bigger to
compensate for ordinary startlines i can fit a 29.5x11.5wx15 which
has 13 inchs of tread and stiff sidewall.
I have 1 inch gap at front of tire will i have clearance probs.
need your knowledge
cheers.
bricki is offline   Reply With Quote
Old 09-16-2012, 08:40 AM   #2
GTX JOHN
Liked 2,462 Times in 694 Posts
Default Re: Hoosier 29.5x11.5Wx15 tire growth.
An Inch should be enough to get by OK!
GTX JOHN is online now   Reply With Quote
Old 09-16-2012, 09:37 AM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Hoosier 29.5x11.5Wx15 tire growth.
You didn't say how wide your rims are. Wider tires can grow more on the same width rim, the taller tire will take up about 1/4" of that 1" clearance, watch it, but you should be safe. But if you can afford it, it can help to go to a wider rim, which actually is recommended anyway. That way you can maintain a fuller contact patch while using more air pressure. It can help slick life, mainly the sidewalls, and top end stability. Many Stock class cars use 10" rims for their rule limited 9" tires.
Old 09-16-2012, 04:24 PM   #4
bricki
Sorry guys my rims are 12 inch car weight is 3000 pound
pics in photo gallery thanks for your replys.
cheers.
